Web VR   [SOLVED] - View the solution
mjaszo
Liked in: 3 posts
Web VR
by mjaszo » Thu Aug 06, 2015 12:13 pm
Hi!
I'd like to add the option to the new project I'm working on.
I'm using Samsung S4 + dive. When it's ON I have a title of the project, an image of the VT mode and the image of the pano. When I click it it shows "Unknown" and I can setup inches, viewer and mm.
And that's when I'm stuck - can't close it and see the pano.
Any tips?
Is using the function described anywhere?
Thanks!
Re: Web VR
by Annis » Thu Aug 06, 2015 12:24 pm
I've moved your post to the PTP 2.5 beta discussion forum.
Once the setup screen has appeared, what happens when you click save? Can you share a screenshot of the screen you're stuck on?
What is the orientation of your device?
Which beta version did you use for the tour?
Can you share the URL to your tour?
Are your panoramas all fully equirectangular 360x180° panoramas? http://www.kolor.com/wiki-en/action/vie ... imitations
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 06, 2015 12:41 pm
There's no SAVE button.
Horizontal (as image suggests in vertical orientation :) )
V2.5.0 Beta 64-bits
Can't share the URL :/
All panos 360x180
Re: Web VR
by Annis » Thu Aug 06, 2015 1:07 pm
mjaszo wrote:There's no SAVE button.
Try turning the phone vertically, on the setup window. Do you see a save button now?
mjaszo wrote:V2.5.0 Beta 64-bits
Beta 1 or Beta 2?
Can you share the URL privately?
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 06, 2015 1:08 pm
2
...and no, can't see any additional buttons in vertical. Only image with "turn to horizontal" appears.
Re: Web VR  [SOLVED]
by Annis » Thu Aug 06, 2015 1:15 pm
What language are you using Panotour Pro in? Polish or English?
If in Polish, see this topic: viewtopic.php?f=117&t=27442
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 06, 2015 1:16 pm
Polish.
Re: Web VR
by Annis » Thu Aug 06, 2015 1:18 pm
Then it's a bug, see the topic I linked above to fix it until beta 3 is available.
