After pressing VR Mode button I see only a white screen
panoguy
by panoguy » Sat Jul 18, 2015 7:34 am
I have downloaded the 2.5 beta version and wanted to build a tour using VR mode.
The tour works and I can see the WebVR icon on the screen as I have enabled VR mode on desktop, but when I click the VR button I get a white blank screen and not the expected menu to select the HMD options.
The same happens even on the mobile (note 4) using the chrome beta browser!
Any idea what I'm doing wrong?
Here a link to the tour I want to build
panoguy
Re: After pressing VR Mode button I see only a white screen
by panoguy » Sat Jul 18, 2015 8:29 am
Just found out if I show the maps and press the VR button after (while maps are still on screen) I don't get the white screen!
Very strange behavior, after hiding the maps the VR button shows again the white screen.
And it works just fine if I remove the maps completely from my tour... But I hope you guys will fix it ;-)
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sat Jul 18, 2015 10:10 am
2.5 beta feedback forum is here > viewforum.php?f=117
This post will be moved... sometime, but post future feedback there.
panoguy
by panoguy » Sat Jul 18, 2015 10:32 am
Thank you, did not see that there is a dedicated forum for 2.5,
For now I have disabled the maps as a workaround but please check if you can reproduce this behavior and get it fixed.
by Destiny » Sat Jul 18, 2015 10:57 am
I moved your post to the right forum... ;)
Cliquetsy likes this post.
by benji33 » Mon Jul 20, 2015 10:06 am
Can't see your VR button to test it ?
panoguy
by panoguy » Mon Jul 20, 2015 5:19 pm
Hi Benjamin,
sorry I had disabled the VR mode to workaround the problem, please try now, you may need to clear browser cache.
by benji33 » Tue Jul 21, 2015 10:41 am
Hi code is encrypted so I cannot have a look, but it seems that the viewer return an error when trying to go to the WebVR mode so the player is never loaded into WebVR mode.
Is it possible to try something ? If yes into the online HTML file replace these lines by the second ones :
function accessWebVr(){
unloadPlayer();
eventUnloadPlugins();
loadPlayer(true);
by
unloadPlayer();
loadPlayer(true);
by benji33 » Tue Jul 21, 2015 11:50 am
EDIT : ok it's an issue when the map is hidden. Once the map is displayed the WebVR button works. I report the issue for correction.
