Multilanguage?
Fabio Musio
Multilanguage?
by Fabio Musio » Mon Jul 06, 2015 4:28 am
On of the files generated by PTP is "youvtourname_messages_en.xml"
Can PTP handle different languages?
I think I've never found information about this function.
Re: Multilanguage?
by Destiny » Mon Jul 06, 2015 5:35 am
Hi.. Not via the GUI.. You can hand code using krpano options.. Just go to their website and do a search.. You can also add the Google Langue bar but tricky.. Can't remember how I did it.. You need to hover your mouse over the menu for a second of the language to change. I thought I read that Kolor are going to add some options.. Not sure...
http://www.destinyvirtualtours.com/PTPV ... ml5=prefer
Likes: 14 posts
Re: Multilanguage?
by bdd » Mon Jul 06, 2015 2:19 pm
Just look the following thread :
viewtopic.php?f=38&t=22321
The idea is :
- to duplicate the file youvtourname_messages_en.xml or its content, and to translate the messages it contains.
- to call an action that will force the plugins to update their content during a language change
But just look to the previous thread, everything is explained there.
Fabio Musio likes this post.
