Web Content Spot Style..
by Destiny » Mon Jul 06, 2015 1:56 am
Hi...
Is there supposed to be some parameters that can be added/edited from Spot Styles for the Web Content...
Using a Mac there is nothing there....
Re: Web Content Spot Style..
by Annis » Mon Jul 06, 2015 8:36 am
Nope, no style parameters for the Web Content Spot, just like the lensflare. What would you have liked to see?
by Destiny » Mon Jul 06, 2015 8:42 am
Whats it there for then...
by Annis » Mon Jul 06, 2015 10:09 am
Because that's how all spots work in Panotour, they have styles to be selected in the spot's properties in the Tour tab, even if they have no parameters than can be modified.
by Destiny » Mon Jul 06, 2015 12:27 pm
I guess its there so more than one Web Page Content can be added.. Just add more from the Plugin Library..
by Annis » Mon Jul 06, 2015 1:04 pm
Destiny wrote:I guess its there so more than one Web Page Content can be added.. Just add more from the Plugin Library..
You can place several Web Content spots with different content using the same style, you don't need different styles.
Fabio Musio
by Fabio Musio » Mon Jul 06, 2015 2:54 pm
How can I know the dimension of the window to properly design a webpage for it?
Likes: 14 posts
by bdd » Mon Jul 06, 2015 3:51 pm
Fabio Musio wrote:How can I know the dimension of the window to properly design a webpage for it?
You cannot know it from inside of PTP.
So, just build your tour with your webcontent spot, and a fake content.
Then edit the XML file of your tour and find the webcontent spot.
Its name begins with "spotwebcontent" .
It has 2 attributes "height" and "width".
It is the height and width you should use, or better use the aspect ratio defined by those 2 attributes.
by mediavets » Mon Jul 06, 2015 4:55 pm
Could these not be spot style properties that could be set within PTP?
Fabio Musio likes this post.
by Destiny » Mon Jul 06, 2015 11:21 pm
OK... I see that working .. So why is there an option to ADD more than one Web Content Spot Style from the Spots Library...
