On video complete
Fabio Musio
On video complete
by Fabio Musio » Sun Jul 05, 2015 4:49 pm
How can I set an action when the video is complete?
So far I can set the video loop, nothing else.
Re: On video complete
by mediavets » Sun Jul 05, 2015 7:11 pm
Fabio Musio wrote:How can I set an action when the video is complete?
In what context is the video playing?
Are we talking about a video as a scene, or a video hotspot, or a video invoked by a hotspot?
Fabio Musio
by Fabio Musio » Sun Jul 05, 2015 7:39 pm
Video as a scene
by mediavets » Sun Jul 05, 2015 9:13 pm
Fabio Musio wrote:Video as a scene
What action would you like to happen after video plays through once?
Fabio Musio
by Fabio Musio » Mon Jul 06, 2015 1:54 am
For example I'd like to go to another pano
Likes: 14 posts
by bdd » Mon Jul 06, 2015 3:18 pm
You cannot do it inside PTP with current version.
You can do it by modifying a little the generated code.
In the yourtour_core.xml file, just find the onxmlcomplete attribute of the videoplayer plugin.
There add the code you want to do.
I'll see if the "Actions" plugin (http://www.kolor.com/wiki-en/action/vie ... our_Events) can be enhanced with this event.
But if its the case, then the action will not be called in VR mode, as this plugin is not exported in VR mode.
Fabio Musio
by Fabio Musio » Mon Jul 06, 2015 4:19 pm
That would be a nice feature to be added. ;)
Terry44 likes this post.
Fabio Musio
by Fabio Musio » Mon Jul 06, 2015 4:25 pm
Also, your solution works if I have just 1 video.
What if I have multiple videos with multiple destinations?
by mediavets » Mon Jul 06, 2015 4:50 pm
bdd wrote:I'll see if the "Actions" plugin (http://www.kolor.com/wiki-en/action/vie ... our_Events) can be enhanced with this event.
Is there a reason why it isn't?
by mediavets » Mon Jul 06, 2015 4:51 pm
Fabio Musio wrote:Also, your solution works if I have just 1 video.
Then you'd need a scene-specfic multi-instance plugin; unless, perhaps, if the destination scene was always the next in the tour order?
Terry44
Likes: 10 posts
by Terry44 » Tue Jul 07, 2015 9:37 am
Something like that could be great Gerald ;). http://360idees.com/360PANO/foirexpo/
Terry44
Likes: 10 posts
by Terry44 » Tue Jul 07, 2015 9:39 am
made it with KRPANO ...tour player under vide player ... i know ... it's a bad player ... but code for video scene to video scene works...
Likes: 14 posts
by bdd » Thu Jul 09, 2015 8:46 am
I did a quick modification in the Advanced plugin "Call actions on tour events" to add this event.
ActionsOnEvents.zip
(2.53 KiB) Downloaded 99 times
I share this modification here on the forum and not on our dedicated page, as the way this onvideocomplete works may change in next beta or in the final 2.5 release.
When the 2.5 version will be out, we will add an official modified version of it.
With this plugin you can set the videoscene ID on which you want it to act. And as you can use this plugin multiple times, you can have many videos in your tour that automatically load next scene on video complete event.
Fabio Musio likes this post.
tarrinos
by tarrinos » Sat Sep 19, 2015 1:07 pm
Merci pour ce plugin qui marche très bien chez moi en mode normal mais ne fonctionne pas en mode VR, j’ai regardé un peu mes XML, mais je ne trouve pas où ce plugin agit ….
Avez-vous une idée de ce que je dois modifier pour le faire fonctionner en VR ?
Dan
Thank you for this plugin that works very well for me in normal mode but does not work in VR mode , I looked a little my XML, but I can not find where this plugin is ... .
Do you have any idea what I need to change to make it work in VR ?
Dan
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sat Sep 19, 2015 1:18 pm
Every plugin is removed in vr mode, it doesnt work.
For the moment you can try have a hotspot in your videos (at the nadir or zenith) to be able to navigate away from the video in VR mode.
tarrinos
by tarrinos » Sat Sep 19, 2015 2:07 pm
Cliquesty thank you
Where is the code generated by the plugin ?
Dan ,
Merci Cliquesty
Où se trouve le code généré par le plugin ?
Dan,
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sat Sep 19, 2015 2:56 pm
Pribably in the tour_skin.XML
tarrinos
by tarrinos » Sun Sep 20, 2015 5:22 pm
yes in tour_skin.xml, it's ok now on vr.
flyeye
by flyeye » Fri Sep 25, 2015 5:22 pm
bdd wrote:I did a quick modification in the Advanced plugin "Call actions on tour events" to add this event.
ActionsOnEvents.zip
when I use this plugin (also with the ID) it's only working at this last video I have placed. All the others (placed before) do not link to another panorama when they are finished and stay at the last frame of the video. Am I forgetting something? Thanks for your support!
by mediavets » Fri Sep 25, 2015 7:20 pm
Have you added multiple instances of the plugin, one for each video scene?
flyeye
by flyeye » Fri Sep 25, 2015 7:35 pm
Yes I did. Each video has his own "Call actions on tour events".
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Fri Sep 25, 2015 8:17 pm
Could you possibly share on online version of the tour?
Also, how about using the basic > load next panorama instead, the next panorama being the next one in pano order.
flyeye
by flyeye » Sat Sep 26, 2015 8:29 am
Hi, thanks for your responses.
I am currently testing the option using “trash” material. So putting the tour online is not a good idea (haha). The action to go direct to the next panorama has unfortunately the same result.
I have now tested the software on a Windows and Apple system. Both give the same result. So I am doing something wrong or forget something, but I do not know what it is. I will keep trying.
by mediavets » Sat Sep 26, 2015 11:00 am
Cliquetsy wrote:Could you possibly share on online version of the tour?
Using PTP 2.5 beta 3 64-bit on Windows 10 Pro 64-bit viewing with latest Firefox...
I created a simple three video scene tour and tried your suggestion...it didn't work instead the video simply stopped and the browser (local viewing using latest Firesox) closed that tab shortly after the initial video scene completed.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sat Sep 26, 2015 12:05 pm
That's weird it's always worked for me.
Did you make it pano specific to each video or general?
If its load next scene you don't need it to be scene specific
