How to start the Samsung Gear VR?
wborre
by wborre » Tue Jun 30, 2015 3:53 pm
I made an Virtual Tour which worked perfectly with my HOMIDO HMD.
But how to use the Samsung Gear VR ?(with galaxy S6)
When I put my S6 in the Gear VR the Oculus software starts automatically.. (and the webbrowser disappears...)
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: How to start the Samsung Gear VR?
by Cliquetsy » Tue Jun 30, 2015 6:08 pm
wborre
by wborre » Tue Jun 30, 2015 8:31 pm
Thank you Cliquetsy.
Unfortunately the Galaxy S6 won't fit in the Gear VR without using the connector...
It will work for galaxy Note 4 .. but not for the S6....
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Tue Jun 30, 2015 9:04 pm
Oh, well i dont know then, that was krpano's instructions (taken from the 1.19 pre-release post) on how to get it in gear vr...
http://krpano.com/forum/wbb/index.php?p ... #post60207
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Tue Jun 30, 2015 10:40 pm
You need to hold the connector up first.. and put the phone under the connector.
Then click it in.
Dit it today and it worked..
Regards,
Xander Berkenhagen
Cliquetsy likes this post.
wborre
by wborre » Wed Jul 01, 2015 9:03 am
Thank you all.
But for the S6 and the (new) Gear VR this isn't possible. Even when I hold the connector up there isn't any space to fit the S6
@Kolor ; Are you planning for a solution for Samsung Gear VR (with S6) ?? because the VR experience is exceptional on this combination (no lag at all)
No space for the S6 Sanmsung Gear VR
by benji33 » Fri Jul 17, 2015 1:29 pm
We are working for the kolor eyes video player under the MILK environnement but not for PTP exports.
As you said, it's impossible to put the S6 with the connector unplugged ?
panoguy
by panoguy » Sat Jul 18, 2015 10:27 am
You could try the following solution:
- Install Package Disabler from the PlayStore
- Open it and check the box on the Gear VR Service
That's it. You can now plug your S6 into the Gear VR without Oculus Home starting up and use Cardboard apps.
To use Oculus Home again, just uncheck the Gear VR Service in Package Disabler.
