Livepano and HMD's
urke
Livepano and HMD's
by urke » Tue Jun 30, 2015 10:02 am
Is the Livepano plugin supposed to work with HMD's? I have tried with no luck.
I have a project containing 13 livepano scenes (hanging PTP 2.5 when exporting on my Mac Pro 2x6GB video + 64GB RAM, but that's another story).
Assuming Livepano won't work, I could make full spherical videos of the scenes. But then again, only one spherical video scene will be supported on Android. And there will be no sound on iPhone (I guess I could hardcode the sound fix used in Krpano 1.19 PR2.)
Any ideas how I could make my project work with HMD's?
Re: Livepano and HMD's
by Destiny » Tue Jun 30, 2015 12:25 pm
Hi.. Do your Livepano's work on a workstation...
urke
by urke » Tue Jun 30, 2015 12:38 pm
Destiny wrote:Hi.. Do your Livepano's work on a workstation...
Yes, works fine on desktop. Works on Android when not in HMD mode.
by Annis » Tue Jun 30, 2015 12:40 pm
So do they not work at all, not auto-play? What is the behavior when in HMD mode? Can you share the link?
Likes: 14 posts
by bdd » Tue Jun 30, 2015 12:51 pm
Video spots do not work with VR mode.
They are automatically removed from the tour when you switch to VR mode.
So Livepano do not work too.
