Recommendations for lenses in specific situations ?
Discuss the various motorized panoramic heads on the market, ask for advice, etc...
(EN/FR Forum)
Jiheffe
by Jiheffe » Sat Apr 28, 2018 9:18 am
I have a GigaPan Epic Pro whith which I've shot lots of panos, mostly outside but also indoors.
I was wondering is there is place somewhere on this site of the web with recommendations as to which lens to use in specific situations? How many images in a pano? How many is overkill?
For example, I recently shot panos with a 50mm lens yielding 13 columns of 9 images to cover a sphere, with 30° overlap. That works great outdoors. I also used the same setup to shoot a booth at a trade show, and it looked to me as, because the distance between the camera and the booth was shorter, I got more small stitching errors, as if the parralax was more a problem because of the shorter distance.
Re: Recommendations for lenses in specific situations ?
by klausesser » Mon May 21, 2018 6:16 pm
Hi!
Inside mid-size and somewhat larger rooms shooting on fullframe i suggest to use max. 35mm lenses @ f8/f11 because of DOF.
This results in 45 shots excluding the Nadir-shot. The Nadir-shot needs to be taken accordingly to the
kind of location. I usually prefer to "close" the Nadir-hole (down-cubeface) by retouching.
I use a motorized head - Panoneed (www.panoneed.com) - which produces a very small Nadir-hole when
i use a 35mm which is easy to fix in Photoshop.
I mean using a 35mm is a very good combination of moderate data-size and an impressing zoom-level
nevertheless.
Here you can see a tour made by using 35mm on fullframe - which means 45 images, as said.
http://www.klausesser.de/KlpH/index.html
Shot @f11 - which provided sufficient DOF.
50mm indoors is not easy to do because of the smaller DOF than a 35mm. To "expand" the DOF you probably need to
use focus-stacking while shooting the rows and collumns twice or thrice using a different focus for each row and combine them in Helicon-Focus to ONE set of 71 pictures for stitching a sphere using a 50mm lens indoors.
Using a very prescise head - which the Panoneed definitely is - you just need to start the sequence two- or three times
changing the focus on each start. This is very easy to do - f8/11 on 35 mm for example provides plenty of DOF for focus-stacking three sequences to one sequence.
Jiheffe
by Jiheffe » Wed May 23, 2018 9:26 pm
Thnx for the advise! Will give it a try :-)
