XML examples
Discuss the various motorized panoramic heads on the market, ask for advice, etc...
(EN/FR Forum)
TravisH
XML examples
by TravisH » Mon Mar 14, 2016 7:22 am
Hi All,
I am looking at programming an xml writer for Arduino and a plan tilt robot and had a few questions. I have seen the xml schema on the webpage but wanted to know more f someone could upload a few papywizard example xml files for me to take a look at.
In terms of the import, do you need to specify the file names and autopano just uses the number of images across the yaw and pitch, and the overlap or does it use other information (E. G. Image dates and times) to work out which files to import.
Just trying to work out what is used to make sure it is included in my script., and if some examples could be shared so I can compare.
