mediavets wrote:What fisheye lens are you using with your 50D?
fma38 wrote:Et tes mosaïques étaient correctes ? Tu avais bien le bon taux de recouvrement en tangage ?
Avec la version 2.1.19, peux-tu envoyer le log, juste après la connexion avec la Merlin ?
2010-07-02 01:43:54,611::Main::INFO::Starting Papywizard...
2010-07-02 01:43:54,658::Main::INFO::Importing modules...
2010-07-02 01:43:54,907::Main::INFO::Loading i18n files...
2010-07-02 01:43:54,924::Main::DEBUG::Papywizard.i18n(): locale=en_US
2010-07-02 01:43:54,924::Main::WARNING::Can't find qt translation file
2010-07-02 01:43:54,924::Main::INFO::Loading Style Sheets...
2010-07-02 01:43:54,924::Main::WARNING::No user Style Sheet found
2010-07-02 01:43:54,924::Main::INFO::Loading configuration...
2010-07-02 01:43:54,938::Main::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '19'], user=[u'2', u'1', u'19']
2010-07-02 01:43:54,938::Main::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2010-07-02 01:43:54,938::Main::INFO::Load plugins...
2010-07-02 01:43:54,938::Main::DEBUG::DslrRemoteProShutter._defineConfig()
2010-07-02 01:43:54,938::Main::TRACE::AbstractPlugin._loadConfig()
2010-07-02 01:43:54,938::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb12@1/2', 'OUTPUT_DIR': 'C:\\Users\\Hans', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\DSLR Remote Pro\\DSLRRemoteTest\\DSLRRemoteTest.exe'}
2010-07-02 01:43:54,938::Main::DEBUG::PluginsManager.register(): added 'DSLR Remote Pro' plugin with capacity 'shutter'
2010-07-02 01:43:54,954::Main::TRACE::EOSUtilityShutter._defineConfig()
2010-07-02 01:43:54,954::Main::TRACE::AbstractPlugin._loadConfig()
2010-07-02 01:43:54,954::Main::DEBUG::AbstractPlugin._loadConfig(): config={'FOCUS_DIRECTION': u'far', 'BRACKETING_TYPE': '0-+', 'BULB_ENABLE': False, 'DRY_RUN': True, 'BULB_BASE_EXPOSURE': 1, 'FOCUS_NB_PICTS': 1, 'BRACKETING_NB_PICTS': 1, 'FOCUS_STEP_COUNT': 1, 'FOCUS_ENABLE': False, 'EOS_UTILITY_VERSION': u'new', 'PROGRAM_PATH': 'C:\\Program Files\\Papywizard\\EOSBracket.exe', 'BRACKETING_STEP': '1', 'FOCUS_STEP': u'medium'}
2010-07-02 01:43:54,954::Main::DEBUG::PluginsManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
Hansenlair wrote:mediavets wrote:What fisheye lens are you using with your 50D?
Samyang 8mm 1:3.5;)
fma38 wrote:Je ne vois rien de bizarre...
Pour être sûr de bien comprendre, l'appareil se met parfaitement au zenith à pitch=+72°, et se met parfaitement au nadir à pitch=-72°, c'est bien ça ?
oui c'est cela
Est-ce qu'il y a un saut ? Je veux dire, est-ce que, par exemple, l'angle est correct jusqu'à 45° (valeur au pif), puis déconne après ? Ou bien as-tu un décalage tout le temps ?
Non c'est un décalage progressif avec l'angle
Essaye de positionner la tête à 45°, en utilisant les flèches, et regarde si la lecture de l'angle donne bien 45°, ou si elle donne 36°.
+/- 35°
Autre test : tu déplaces la tête en manuel, et tu regardes si le codage est bien continu, ou s'il change brutalement de valeur à un moment donnée.
mediavets wrote:Hansenlair wrote:mediavets wrote:What fisheye lens are you using with your 50D?
Samyang 8mm 1:3.5;)
What shooting pattern are you using for your custom preset?
I think that with a Samyang FE on a Canon 50D you should use one of these patterns:
1. 6-around at about -15 degrees pitch and 60 degree yaw separation, plus one or two up at about +65 degrees pitch and say 120 degrees yaw separation; this should be OK for most outdoor scenes.
2. 6-around at about -15 degrees pitch and 60 dgrees yaw separation, and 6-around at about +50 degrees pitch and 60 dg4rees yaw separation: this may be better for interiors.
Merci pour ces conseils, je teste dès que possible.
Do you have your camera/lens set at the NPP (No Parrallax Point)?
fma38 wrote:Tiens-nous au courant.
