Which laptop is best for Autopano Video
Your computers are also an important part in the creation of immersive content. Discuss configurations and computer hardware here.
(EN/FR Forum)
atwexchange
Re: Which laptop is best for Autopano Video
by atwexchange » Mon Oct 10, 2016 1:53 pm
i'm using intel hd3000, and working fine
milijacob
by milijacob » Wed Dec 14, 2016 9:55 am
I have been using Intel HD3000 and is working well for the Autopano Video. You can make use of PC's with multicore CPU, mother board and RAM have the compatible speed like that of core i7 CPU's.
pghero
by pghero » Wed Feb 08, 2017 12:07 am
ASUS typically can meet those specs.
Very easy to find the right one with Google.
angeldazydoll
by angeldazydoll » Wed Feb 08, 2017 7:08 am
Lenovo I3 is best for Autopano
DeenaJoshi
by DeenaJoshi » Mon Feb 27, 2017 6:40 am
Hi, I suggest you to go for ASUS. I guess you will be comfortable with the laptop according to the specifications you have mentioned.
DeenaJoshi
by DeenaJoshi » Wed Mar 22, 2017 6:04 am
Hi, By looking at the specification Macbook Pro 13 sounds to be the better option. Even if its bit expensive its worth spending and it will be like your one time investment. If you want to have other options better go for ASUS. but you might not get these specifications exactly.
madonamurfy
by madonamurfy » Sat May 13, 2017 7:28 am
I am using asus A555l which is te best model of the Asus serious. I think it will be fit for the software which you wanna use. its contains 4 gb ram and 1TB HDD with the extent battery Life.Promoocodes.com is the biggest discount voucher platform where you can try all the best deals for you first laptop purchase. so keep in touch.
andreabelly
by andreabelly » Thu Jul 06, 2017 8:39 am
I think MYy laptop is best for the autopano video because i have got 4 gm ram and 1 tb hdd. this is the much space to install this application in My pc, but i have only the windows 7 32bit. so it is compatible for this application. 1 year web hosting is also the best choice for beginners.
abikachennai
by abikachennai » Fri Dec 29, 2017 7:57 am
Hello All,
Basically the below should be the specification that Autopano video recommends,
Negligible arrangement
Working framework:
Microsoft Windows 7, 8, 10 prescribed (64 bits frameworks very recommended)*
Apple Mac OS X Yosemite, El Capitan and macOS Sierra (64 bits as it were)
Ubuntu 16.04 64 bits (CUDA bolstered yet with no official help)
Show: determination of 1280x1024 least
Processor: 1 GHz
50 GB hard circle space
Slam: 6 GB
A current designs card (NVIDIA or AMD prescribed) with 512 Mb devoted memory and cutting-edge illustrations drivers
Note: We prescribe utilizing no less than a NVIDIA GTX 760 to empower CUDA quickening with Autopano Video 3
Prescribed design
Show: determination of 1920x1080
Two full HD screens are prescribed for best workspace comfort.
A 2 GHz processor or more
Multi-center processors
256 GB SSD hard drive
8 GB of RAM or more
A current designs card (NVIDIA or AMD prescribed) with 2 GB committed memory and state-of-the-art illustrations PROPRIETARY drivers
On the off chance that you claim a coordinated Intel GPU and a NVIDIA card, you can choose which GPU to use with Autopano or some other application: on Windows, right tap on your work area, select NVIDIA control board, at that point select Autopano to be utilized with the NVIDIA GPU.
Numerous GPU are not upheld.
Note: We suggest utilizing no less than a NVIDIA GTX 760 to empower CUDA increasing speed with Autopano Video 3
* We can not ensure similarity with more established Windows frameworks like Vista, XP or 2000 as well as 32 bits frameworks.
John32
by John32 » Sun Jan 21, 2018 3:38 pm
All paper writing companies try to assure you in providing the best services to attract as many college students as possible. Of course, there are services that keep their promise. However, there are also services that do not care about delivering quality essay help but only want to get your money. Read the detailed edubirdie reviews in order to not be scammed.
annamolly
by annamolly » Thu Feb 01, 2018 1:06 pm
We come out with exclusive finance homework help ensuring that you can find a complete plagiarism free paper. Our services are the best ones that even turn out within your budget.
