Omni rig only kit , pricing & firmware effects
Discuss the various camera RIGs on the market, ask for advice, etc...
(EN/FR Forum)
pana2000
Liked in: 5 posts
by pana2000 » Sat Aug 20, 2016 5:27 am
Appears the omni rig only option comes with just the omni rig ?
Looks like a great inclusive buy with software also included far better priced then buying the components separately
Would be a great option if current Kolor / Gopro users with software and gopros could upgrade to the full omni kit
That includes the battery, battery charger, plate cable ( and was there a case ? ) Thanks if you can do it Kolor :)
Also anyone have any idea what alterations the omni firmware makes to the Gopro Think I read about FOV / Res Not sure
And if that's the case can the cameras firmware be flashed back if required for conventional non 360 use
Re: Omni rig only kit , pricing & firmware effects
by Annis » Mon Aug 22, 2016 3:28 pm
The Omni firmware allows the GoPros to be synchronised so that they all share the same settings and start at the same time.
You can of course change the firmware back to the non-Omni firmware (and back again), but the Omni firmware is needed if you want to use that GoPro with the Omni.
pana2000
Liked in: 5 posts
by pana2000 » Mon Aug 22, 2016 3:47 pm
Thanks Annis
Annis likes this post.
macalenny
by macalenny » Thu Sep 08, 2016 6:06 am
where can we buy the external charger for Omni if we bought the rig only kit?
This is a must have feature I am excited to use.
Can we buy it alone?
thanks!
pana2000
Liked in: 5 posts
by pana2000 » Wed Sep 14, 2016 4:08 am
Still hoping the kit may be available without cams down the track Just an extra thought Perhaps it could be powered off standard vlock battery's They are about 12 to 14 volt
JaneSmith76
by JaneSmith76 » Sat Aug 19, 2017 7:45 am
The Omni firmware allows the GoPros to be synchronised in order that they all share the same settings and begin at exactly the same time.
Five nights at freddy’s
