Freedom 360 rig heat issues
Discuss the various camera RIGs on the market, ask for advice, etc...
(EN/FR Forum)
oscargramer
by oscargramer » Wed Jun 15, 2016 2:09 pm
I recently purchased the standard freedom360 bundle rig from Kolor. It works fine for shorter clips but if I run it for more than 15 minutes or so then cameras will start shutting down due to overheating. I even put the hole thing in the fridge and started a recording but even then they would start to shut down after 20 minutes.
I'm shooting at 1440p 60 FPS with wi-fi on connected to the GoPro remote.
Any advice on how to lessen this problem? If not with this rig then which one? I know GoPro's omni will be aluminum and looks to have a more airy design that hopefully solves the issue, but I can't wait 'til august. I'm looking to make longer running shoots. Preferably around an hour or longer if possible.
Re: Freedom 360 rig heat issues
by gkaefer » Sun Aug 21, 2016 1:30 am
I have no gopro, nore the freedom rig...
is it a rig problem or a camera problem?
does a single gopro shutodnw after 20 minutes?
oscargramer
by oscargramer » Tue Aug 23, 2016 8:55 am
it's a problem related to the freedom 360-rig in use with the hero 4-cameras. GoPro's own rig hopefully doesn't have this issue. I've somewhat solved my own problem by lowering the recording resolution to 960p.
