Nodal Point - Nodal Ninja RS 2 ring mount
Discuss the various manual panoramic heads on the market, ask for advice, etc...
(EN/FR Forum)
Marc Lucas
by Marc Lucas » Sun Dec 11, 2016 11:13 pm
Hi
Just got the Nodal Ninja RS 2 and using the ring mount adaptor for the Sigma 8mm fisheye. The only way to achieve the Nodal point is to position the camera so far back that the side of the bracket can be seen in lens. Is this going to cause problems with the stitching or will the overlap (taking 3 images with a 180degrees lens) sort things out?
Liked in: 226 posts
Re: Nodal Point - Nodal Ninja RS 2 ring mount
by Destiny » Mon Dec 12, 2016 12:51 am
Hi.. That does not sound right.. I would suggest you check in with Bill Bailey @ Nodal Ninja and ask him for some suggestions on this.. He will respond very quickly....
Marc Lucas
by Marc Lucas » Mon Dec 12, 2016 1:07 am
I'm also going to contact the vendor and see what they suggest also. Do you just send a contact email to Bill through the site?
Liked in: 226 posts
by Destiny » Mon Dec 12, 2016 2:11 am
Yes, I think so. He will read your message fairly quickly but don't forget they are in the US...
Marc Lucas wrote:I'm also going to contact the vendor and see what they suggest also. Do you just send a contact email to Bill through the site?
jimbee
Likes: 8 posts
Liked in: 13 posts
by jimbee » Thu May 11, 2017 3:15 pm
Good if you can post here what you find out.
