Programming of the ATTINY85 on my camera
Discuss cameras used for shooting panoramas, virtual tours or 360° videos (GoPros, DSLRs, one shot cams, etc..) and their various accessoires (lenses, monopods/tripods, etc...).
(EN/FR Forum)
adawang
by adawang » Wed Apr 05, 2017 7:59 am
Still working on my camera trap and need to have a very basic program to control two outputs with one input.
It is an infrared camera trap working on a 38khz system, everything is already made except for the programming of the ATTINY85 that will run it.
I need two outputs: when one is high, the other needs to be low and vice versa so that when the beam from the emitter is being received, output 1 is high and output 2 is low. Breaking of the beam would reverse this and when the beam is visible again it would go back to its original state.
The input is from the output of a TSSAL through an optocoupler, so basically a switch.
This is the code I have, and it does not work, and I cannot figure out why.
const int LED1 = 0;
const int LED2 = 1;
const int SW = 2;
 int val=0;
void setup()
  pinMode(LED1,OUTPUT);
  pinMode(LED2,OUTPUT);
  pinMode(SW, INPUT);
 void loop()
   val=digitalRead(SW);
if(val==0)
digitalWrite(LED1,HIGH);
digitalWrite(LED2,LOW);
else
if(val==1)
  digitalWrite(LED1,LOW);
  digitalWrite(LED2,HIGH);
Something I also would like to see is each time the outputs change, there is a slight delay of maybe 60ms before the output that is being switched off goes to low, but no delay in the other output going to high - so a bit of an overlap. This is important for the camera as it needs 56ms to respond.
Any help is greatly appreciated.
Christian Stüben
Likes: 3 posts
Liked in: 8 posts
Re: Programming of the ATTINY85 on my camera
by Christian Stüben » Fri Apr 21, 2017 7:02 am
try to change the loop code:
void loop()
if(digitalRead(SW)==0)
else
Do you really need the val variable? is it needed somewhere else in your code?
I dont know the attini and its compilers, and what might be done automatically for a procedure that is called loop.
In my opinion without additional code, it really doesnt loop.
greetings from germany
Chris
Christian Stüben
Likes: 3 posts
Liked in: 8 posts
by Christian Stüben » Fri Apr 21, 2017 7:10 am
for the funny delay problem, try to exchange the sequence you set the led to high and low.
Somebody
by Somebody » Thu Jun 22, 2017 7:48 am
Has the same problem a while ago, good to know I am not the only one tp strugge with it ;)
I wrote to the shop, they helped me out quickly.
Now all is great, making decent pictures of real estate in Barcelona https://tranio.com/spain/catalonia/barcelona/
Tooom
by Tooom » Tue Aug 15, 2017 9:13 am
