fuji or canon
Discuss cameras used for shooting panoramas, virtual tours or 360° videos (GoPros, DSLRs, one shot cams, etc..) and their various accessoires (lenses, monopods/tripods, etc...).
(EN/FR Forum)
man360
fuji or canon
by man360 » Sun Dec 27, 2015 9:59 pm
I have a panosaurus 2 head, but not having much success in producing error free panoramas. most of the errors appear as black triangles or square spaces not sure how to fix this or what causes them.
I have used a canon 60D with 17-40 mm , little success. Found this combo a little heavy for the panosaurus.
And also used a Fuji X-E2 with 18=55mm shooting 32 images ! The Fuji is producing more regular success but still have the black triangles,
Any ideas ?
Anybody else using the fuji ? I am thinking about the samyang 8mm ?????
Re: fuji or canon
by Destiny » Sun Dec 27, 2015 10:25 pm
Hi... Seems you are not covering enough of the scene. For that rig I would go with a 10.5mm fisheye.. Far easier than a normal lens.. A fisheye will need far fewer images to capture a full sphere... If not the 10.5 fisheye, investigate others..
