[V1.4.0 RC 2 OSX] random checkbox sensitivity in layer view
james.anderson
by james.anderson » Tue Oct 16, 2007 1:03 pm
app : autopano pro 1.4.0 RC1
os : os x 10.4.10
monitors : 3 monitors attached.
action :
enable the layer view in a panorama editor
click the "blended layer" triangle to reveal the image list
click a check-box to hide an image
result :
sometimes it works, sometimes it doesn't
sometimes double-click does a quick disable/enable, immediately after which the check box works
sometimes it helps to have the item already selected.
reproducible : so far, every time i have edited a panorama
regression : do not recall this from rc1
james.anderson
by james.anderson » Tue Oct 16, 2007 3:08 pm
update.
it seems to depend on where on clicks in the box.
lower left corner works. upper right does not.
by AlexandreJ » Tue Oct 16, 2007 6:20 pm
We don't have any way to change that, but I agree that's a bit weird.
[bo]
by [bo] » Wed Oct 17, 2007 9:11 am
So it's a bug that's not really fixable? Do I post it at "left for another release", or just archive this topic?
On a side note, I really like the way James includes the "3 monitors attached" line to each post ;) ! I've never seen someone get so many crashes (I wonder how you even manage to get any panos done), so it must be the three monitors messing up with APP :D !
machart
by machart » Wed Oct 17, 2007 10:35 am
i can confirm that error (like most of the others), and james is right with the reason, why sometimes the checkboxes dont react!
but as i know, in the interface builder you can arrange checkboxes, but there is nothing like a "hot" area to change... so i dont know how it can come to that interface error...
and [bo]: yes, since rc1 its almost impossible to work with APP on a mac, because of the permanent crashes!!! ;/
::: close to the rainbow :::
D300S, 18-200mm, 10,5mm, NN3, iMac i7
http://panographie.net
james.anderson
by james.anderson » Wed Oct 17, 2007 2:57 pm
well, the reports also indicate that i manage to work through several dozen panoramas before it crashes.
at least that is better than rc1, which tended to manage about half a dozen...
