Custom HTML/Code for Protected Panotour Pro
Here you can post your job offers, if you are looking for someone to help you or do the work for you.
See the sub-forum rules / Règles du forum.
English version. - Pour la version française de l'annonce, cliquez ici!
Here you can post your job offers, if you are looking for someone to help you or do the work for you. 'The work' includes (but is not limited to):
    • - Shooting ( panoramas , V360° )
    • - Stitching ( panoramas , V360° )
    • - Virtual Tour creation
    • - Custom plugin creation
    • - Custom HTML coding
  • - You will post the offer only once per project. If you have several projects at different times you are permitted to post again.
  • - Once you have posted, the offer will be locked. All users have locking rights (but not unlocking) on these forums. You can lock the post from the bottom of the page.
  • - If you need to edit, contact the forum administrator (Annis) with your changes.
  • - If someone is interested in the offer, they will send you a PM (Private Message) to discuss details and prices.
  • - If the offer is no longer available or completed, the OP must check the topic as [N/A]
  • - If your topic does not follow these rules or the Community Marketplace rules, your topic will and can be deleted without notice.
Thanks for reading,
Fireweed
by Fireweed » Tue Mar 06, 2018 11:48 pm
I have a web server that is running out of file space with approximately 150 projects (tours). This year I anticipate ~200 more tours. So I need to move my previous and future tours to the cloud. The tours need to be private, so using Amazon S3 as a static website is not a option.
I have not fully committed to a cloud option for this yet. As i company we have Amazon S3, Dropbox and Sharefile accounts.
So I need a script to run or code I can insert myself to each Panotour project that can serve protected Panotour projects from the cloud to my web server.
Willing to pay.
Travis
Re: Custom HTML/Code for Protected Panotour Pro
by Destiny » Tue Mar 27, 2018 1:57 am
Use this kind of option to encrypt your html and then use krpano to encrypt your xml..
http://www.webtoolhub.com/tn561359-html-encrypter.aspx
