Compile Data in Pro because a bug in Demo   [SOLVED] - View the solution
zechelon
by zechelon » Thu Nov 24, 2016 12:08 pm
sadly there is a bug in the Panotour-Demo at 2.5.5 so it is impossible to compile a projekt for VR. You can not exit the menu and so it is nearly impossible to test the VR with the demo.
Bug is explained here: viewtopic.php?f=92&t=34082
It is possible for somebody to compile and send me a testprojekt?
Should be everything finished in http://zechelon.bplaced.net/Grafiken.zip and it should be minimal effort of maximal a minute.
Should be just one klick and the sending via dropbox or wetransfer :)
Thanks!
Zechelon
