Panotour Maps not showing google maps
sattan
by sattan » Mon Jul 02, 2018 9:46 am
I have a issue lately where I create a tour and making use auto hotspot in the Panotour Maps plugins but after building the tour the map does not show. It said "Sorry! Something went wrong. This page didn't load Google Maps correctly. See the JavaScript console for technical details." This is only happen this few days before I create few projects but does not have this error.
Thanks and Regards,
TT
Likes: 14 posts
Re: Panotour Maps not showing google maps
by bdd » Mon Jul 02, 2018 10:59 am
Did you enter an API key in the "Main map key" field in the plugin properties ?
http://www.kolor.com/wiki-en/action/vie ... OTOUR_MAPS
sattan
by sattan » Tue Jul 03, 2018 1:18 am
No, I didn't. I did not enter any API key previously too for my older project but still it works.
by Destiny » Tue Jul 03, 2018 1:46 am
It all changed a long time ago.. You need to go to Google and apply for a API number, which is free unless you are a very heavy user... Then I think they charge you... Same with other maps.. You need a pin number..
