How to open Gallery Plugin from Bootstrap Control Bar   [SOLVED] - View the solution
Pak
by Pak » Mon Feb 19, 2018 6:54 pm
Hi everybody,
I successfully added in the Control Bar of "Bootstrap Full Page with Project Colors" template another button that i'd like to use to call my Gallery Plugin (named "mygallery"). I don't want to use an image because with responsive design the only way to have everything in order is a button part of the control bar so I added the new button by copying the html code from others buttons and, after changing the span class in "glyphicon-camera", I'll find an excellent way to show in my Tour a Control Bar with a nice Camera button too :)
That's the code I copied and added in the button list:
<button type="button"
class="btn btn-default btn-lg"
onClick=....
data-toggle="tooltip"
data-placement="top"
title="Show Gallery">
<span class="glyphicon glyphicon-camera"></span></button>
The problem, as you can see, is to find the right function (onClick=....) to call "mygallery".
I tried to use many strings I found in the other buttons and in your forum as
onClick="getTourPlayer().call(mygallery))"...
onClick="getTourPlayer().callToAction(mygallery))" ...
onClick="getTourPlayer().call('showmygallery()')" ... or
onClick="getTourPlayer().call('mainloadscene(mygallery)')"
but none of these works :(
Maybe the code need also more lines of information in order to open "mygallery" but unfortunately I have no experience of scripts so I hope you can help me because I'm sure this easy solution could be very useful for everybody.
Thank you!
Likes: 14 posts
Liked in: 129 posts
Re: How to open Gallery Plugin from Bootstrap Control Bar  [SOLVED]
by bdd » Tue Feb 20, 2018 10:12 am
The name of the action to call depends on the ID of your Gallery plugin.
Open the file "mytour_skin.xml", find your Gallery plugin description. It begins with a comment like this one :
<!-- Gallery -->
<!-- id : yourgalleryID -->
Then go down in the XML file, until you see an action named like this : showGallery_yourgalleryID .
By default, if you have only one gallery, and if you did not rename the plugin, the action will be : showGallery_gallery
So the right call is :
onClick="getTourPlayer().call('showGallery_yourgalleryID()')"
By default it may be :
onClick="getTourPlayer().call('showGallery_gallery()')"
Pak
by Pak » Tue Feb 20, 2018 1:00 pm
That works !!!!! =D =D =D =D
Thank you very much Gérald :)
