Customizable [htmlheadscripts.tmpl]
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Tue Feb 28, 2017 4:52 am
Hello PTP team
I plan to create an html plugin that is divided into two parts: for head and for div, both of which must be used at a html file.
How to use customizable htmlheadscripts.tmpl, like pluginshtmltemplates.tmpl is used in PTP Plugin?
Thanks for any help!
Dashan
eMail: 446426990@qq.com dspano@live.cn
Re: Customizable [htmlheadscripts.tmpl]
by Annis » Tue Feb 28, 2017 10:07 am
The internal templates aren't available to be edited to ensure compatibility of the html templates with future versions of PTP.
The only one available that has been expanded is the metatags template, which was posted on the forum here: viewtopic.php?f=93&t=25625&p=158787#p158787
If you are going to create a plugin to edit these fields, why not just create a new .tmpl directly?
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Mon Mar 13, 2017 5:04 am
But the HTML plugin in PTP can only add the code to a location in the HTML.
I need a way to have different HTML plugins insert the code into different places in the HTML.
Tanks Annis
Dashan
