pano object introspection?
bitbyter
Liked in: 3 posts
by bitbyter » Fri Feb 17, 2017 3:11 am
Hi - I've been trying to tweak an HTML template for a specialized purpose and have attempted to discover which properties/variables are associated with the "pano" object. Specifically, I'm trying to determine if a scene is planar or not ...however I can't figure out how to test this property within the HTML template.
Other template authors have used {{pano.tourId}}, {{pano.description.name}}, {{pano.description.description}}, and {{pano.thumbnailPath}} within HTML templates and I am at a loss to find any definition of the pano object within docs or forums. Have tried to use Django debug to describe the object but it doesn't reveal anything.
Can anyone tell me how to get a description of the pano object and its public variables as it appears to HTML template?
Thx, Scott
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: pano object introspection?
by 360-compunics-com-ni » Fri Feb 17, 2017 4:19 am
Hi Scott,
i would like to have that documentation as well.. regarding the "planar-check" i found something by greping through the original plugins templates:
{% if pano.isPlanar %}OK{% else %}NO{% endif %}
Bye,
Michael
bitbyter
Liked in: 3 posts
by bitbyter » Fri Feb 17, 2017 6:48 am
WOW! Have tried this and it's already solved my immediate problem - Thank You Michael!
I am curious where you found it though - I also tried greping for "planar" and could not find any templates that had this phrase. By "original" are you referring to legacy plugins that are no longer distributed?
Thanks again!
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Fri Feb 17, 2017 3:22 pm
On Linux i found it in "/usr/share/PanotourPro/Resources/plugins/floorPlan/kolorFloorPlan.tmpl", and it is used in the "kolorMap.tmpl"-file as well. Both are very interesting to study, but i don't know their locations on other platforms.
by Annis » Fri Feb 17, 2017 3:33 pm
360-compunics-com-ni wrote:but i don't know their locations on other platforms.
No matter the OS you can find those folders this way:
Open Panotour > Edit > Open Templates System folder > Plugins and select the plugin you want to study. :)
benji33 likes this post.
bitbyter
Liked in: 3 posts
by bitbyter » Fri Feb 17, 2017 4:03 pm
Thanks to you both!
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Aug 05, 2018 9:37 am
Not sure what your use case is, but maybe you can get some hints out of this great example using two synchronized tours to get the "before/after"- or "day/night"-effect: http://www.kolor.com/forum/viewtopic.php?f=26&t=34651
The "chair"-symbol in the upper left corner of the demotour switches between the two tours.
