Find Object Game - changing the increment settings   [SOLVED] - View the solution
bnutton1
by bnutton1 » Mon Jan 23, 2017 3:19 pm
Hi Kolor Community,
I have the Find Object Game plugin installed, and I was hoping to get some advice on how I would adapt it so the increment trigger doesn't go off when nb=max, instead triggers when the nb=max hotspot is closed (rather than firing upon being opened which it does)
Any help would be greatly appreciated.
Thanks all
Likes: 14 posts
Re: Find Object Game - changing the increment settings
by bdd » Mon Jan 23, 2017 3:51 pm
I think I did not understand your question.
What I understood is that you want the hotspot to be closed before the "nb=max" action is triggered.
But it is already the case.
Here is the steps done after the last click :
1/ The spot is clicked
2/ The internal counter is incremented
3/ The spot is removed
4/ the message is updated with the new counter
5/ the custom action is called
Can you tell me more about your need, because I think I did not understand them ?
bnutton1
by bnutton1 » Mon Jan 23, 2017 4:06 pm
Hi Gerald,
Thanks for taking the time to get back to me.
Currently I have 5 point hotspots - all of which when clicked display individual urls in web boxes.
When the "Find Object Game" is complete (all 5 hotspots have been clicked) I want to automatically trigger the end event - which will be to load another web box.
Problem is upon clicking the 5th Hotspot it automatically fires the end trigger of loading another web box. What I would like is for this to be triggered when the user closes the 5th hotspoint - not clicks to open.
Hope this makes a little bit more sense :s
Likes: 14 posts
Re: Find Object Game - changing the increment settings  [SOLVED]
by bdd » Mon Jan 23, 2017 4:43 pm
OK, now I understand.
You can't do it through PTP interface.
You'll have to change the generated code once the tour is built.
The plugin code can be changed a little to ease the modifications, but even with a modified plugin, you'll have to edit the xxx_skin.xml file.
1/ Edit the xxx_skin.xml file
2/ Find the action called "incrementcountergame"
  <action name="incrementcountergame">
    inc(countergamenb);
    txtadd(countergameremovedelements, get(countergameremovedelements), xx, get(%1));
    updatecountergame();
    if (countergamenb == countergamemax,
     xxx your custom action called on the last spot
  </action>
3/ Modify it like this :
    inc(countergamenb);
  </action>
  <action name="nbequalsmaxaction">
  </action>
4/ Find the action called when the Website box displayed on a spot clicked is closed.
It's name should be something like this "closeKolorBoxCallback_websiteViewerXX" where X is a number if you have different website boxes.
5/ Add the following line at the end of the action :
nbequalsmaxaction();
like this :
<action name="closeKolorBoxCallback_websiteViewer">
     resumeautorotation(forceplugin);
   set(ptplugin[websiteViewer].isOpen, false);
</action>
It will do what you want, but you'll need to have a different website box plugin for the final displayed box.
bnutton1
by bnutton1 » Thu Jan 26, 2017 2:41 pm
Brilliant, Thanks Gerald. Worked a treat :)
