Web Interface Responding to Control Bar Button
RoryG
Likes: 3 posts
Liked in: 3 posts
by RoryG » Sun Jan 08, 2017 9:53 pm
I've used a Bootstrap template for my tour and customised the CSS and menu bar to fit my theme. I'm happy with the way it looks but I would like the HTML to respond to the hide controls icon to collapse the menu bar. I've written the code to show/hide the menu bar but have no idea how I can trigger it from inside the tour, likely a JavaScript function or editing the XML required? Anyone done this?
Cheers,
Rory
oblanc
Liked in: 3 posts
Re: Web Interface Responding to Control Bar Button
by oblanc » Mon Jan 09, 2017 10:12 am
Hello
You need to show/hide navigation bar and adjust #panoDIV accordingly
To hide navbar
jQuery('nav.navbar').hide();
jQuery('#panoDIV').height('100%');
To show navbar
jQuery('nav.navbar').show();
var finalHeight = jQuery(window).height() - jQuery('nav.navbar').height();
jQuery('#panoDIV').height(finalHeight);
Hope it helps
