I want to limit only "nomalview" Zenith and nadir should be visible in all other projections. Maybe it helps unexperimented viewers not to get lost right from the beginning.
1. Is ist only the XXX_skin.xml I have to modify?
2. Beside this I want to have a glimps of fisheye (maybe 0.4) in the view. Whitch parameters I have to change or add, please?
Thank you! Martin
Copy of NormalView in XXX_skin.xml (line 1257 to 1284)
