<elementlist>attribute BUG urgent need to be resolved!
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Tue Oct 18, 2016 12:12 pm
Hi kolor team,
Many of the plug-in advanced features require a <elementlist>, but now the <elementlist> BUG is very fatal, has been found in the plug-in abbreviation process many crashes related to it.
This is how I use it:
<!--  in plug_info.xml -->
<elementlist ... >
   <actionlist id="EnterActions" name="tr:..." >
        <actionchooser id="EnterAction" name="tr:Action " />
    </actionlist>
    <actionlist id="QuitActions" name="tr:..." >
    </actionlist>
</elementlist>
<!-- To be called xxx.xml -->
<action id="dsScrollTextCall" name="tr:..."callTemplate="dsScrollTextCall.tmpl">
      <string id="CallText" name="tr:..." default=""/>
 </action>
<!-- To be called xxx.tmpl of xxx.xml -->
{% if action.plugin %}
        ...{{action.CallText.messageid}}...
{% endif %}
best regards
in plug_info.xml
in xxx.tmpl
Dashan
eMail: 446426990@qq.com dspano@live.cn
Re: <elementlist>attribute BUG urgent need to be resolved!
by Annis » Tue Oct 18, 2016 12:59 pm
It isn't a bug it's a limitation of the code.
You can not place an action list in an element list (and vice versa).
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Tue Oct 18, 2016 4:23 pm
That's a shame, and using the structure shown above can save me a lot of "workspace" space, and one of my roaming might use more than 50 plugins (or replicas).
That's a shame, and using the structure shown above can save me a lot of "workspace" space, and one of my roaming might use more than 50 plugins (or replicas). You can consider the solution?
Dashan
