TourHighlights - modify the code after rendering
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Thu Oct 06, 2016 4:20 pm
Hi All, i had use the plugin tourhighlight combien with the plugin Spot Range to make a "automatic" tour include hotspot, but i have to modify some values and i cannot find the values of fov,turnspeed and wait of this plugin.
Thank you and have a nice day,
Gabriel.
Bonjour à tous,
j'ai utilisé le plugin tourhighlight combiné au plugin spot range pour faire une visite virtuelle automatique incluant l'affichage des hotspots. Je dois modifier quelques valeurs du plugin après rendu, et je ne trouve pas ces valeurs dans aucun xml.
Merci et bonne journée,
Gabriel.
gabriel
Likes: 15 posts
Liked in: 13 posts
Re: TourHighlights - modify the code after rendering
by gabriel » Thu Oct 06, 2016 11:09 pm
ex :
<data name="fr_spotpoint12_description"><![CDATA[220;55;35]]></data>
PS : i have seen the CDATA into the message.xml, but changing these values have no result ! thank you and have a nice day.
PS : changer les valeurs du plugin dans message.xml n'a pas d'action ! Merci et bonne journée.
Gabriel.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Fri Oct 07, 2016 3:47 am
Hi Gabriel,
i don't know the Spot Range plugin until now, so i cannot say if there is any impact between both plugins.
Changing the TourHighlights-settings via the message.xml should work as well, but why not change those values using the PTP GUI?
Regarding the values you have posted, you probably got the sequence wrong:
FOV: field of view (or zoom-factor): values between 1 and 179°
Speed: movement in degrees per second (default: 120)
Wait: time in seconds before the next movement
That is, the first value has to be between 1 and 179, and so on. I will probably add a check for that in a future version.
The zooming also depends on your pano and zoom limit settings, you might check that in the pano preview window.
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Fri Oct 07, 2016 11:41 am
Hi Compunics,
Thank you for your rapid answer, i just sent you a PM because it's about a project not finish yet.
Yes, the 220 value is not good, it was just to give a sample but it works anyway ;-)
Have a nice day,
Gabriel.
janice
by janice » Fri Dec 30, 2016 4:05 am
Can TourHighlights do pause and start?
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Fri Dec 30, 2016 12:20 pm
Hi Janice,
yes, it can. If you want to see a sample :http://www.gabrielacoca.fr/musee-bourdelle/visite-guidee/index.html
then click on the bon left-bottom ( the man with the hat )
Have a nice day,
Gabriel.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Mon Jan 02, 2017 12:11 am
The TourHighlights plugin was not dsigned with a 'pause/resume'-feature. If it works for you this way probably because of a casual interference with the Spot Range plugin. The TourHighlights option to let the user interrupt the presentation mode really means to terminate it.
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Mon Jan 02, 2017 3:31 am
True, i forget that !
Have a good year ;-)
Gabriel.
