Hide Bootstrap menu in VR mode
chris_w
Likes: 4 posts
by chris_w » Mon Sep 05, 2016 1:27 pm
Hi there,
I wonder how one could hide a Bootstrap menu based on the HTML-template Bootstrap_Hierarchical_Top_Navbar_2016_08.html entering VR mode and show it again after leaving VR mode (see my tour at http://bit.ly/2bNBzVg ). Any ideas someone?
Best regards,
Chris
oblanc
Liked in: 3 posts
Re: Hide Bootstrap menu in VR mode
by oblanc » Wed Sep 07, 2016 7:51 am
Hello
yes that's because navbar is into #tourDIV.
This template has to be upgraded to support VR mode.
In the meantime, here is what you can do:
Edit the template by moving <nav> tag up into div#container like this
Note that with this method, fullscreen mode will not display navigation bar.
Hope it helps
katherinego
Likes: 3 posts
by katherinego » Tue Nov 15, 2016 1:35 am
chris_w wrote:Hi there,
Best regards,
Chris
Hi Chris, thanks for sharing your example tour. It is very close to what I am working on. I am trying to add a VR Mode icon to the Nav bar like you did.
Can you share your code for the Nav Bar?
-katherine
by Annis » Tue Nov 15, 2016 9:23 am
Best regards,
Chris
-katherine
Check your control bar's settings, you should have an option to add the VR Mode button to the control bar, just like for any other button.
If it isn't there, try removing the control bar's plugin from the project and adding it back again.
