Floorplan to start open deep-linking   [SOLVED] - View the solution
Sean King
Liked in: 4 posts
by Sean King » Mon Aug 22, 2016 7:09 am
My client would like to send a URL of his tour in an email with the floor plan open.
However, he still wants the tour in his homepage to start with the floor plan closed.
Is there any way to add something to the end of the URL of his tour, so that his tour starts with the floor plan open?
Sort of like when you add deep links to the URL to start on a specific panorama, ?s=pano31&h=0.0003&v=0.0000&f=90.0000
But instead the Information at the end of the URL would start the tour with the floorplan open.
Thanks for the help.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Floorplan to start open  [SOLVED]
by 360-compunics-com-ni » Mon Aug 22, 2016 1:50 pm
Can be done with an additional function that looks for an "url-switch", lets say: "fpopen=true" on startup.
The URL to open the floorplan then would look like: ?s=pano31&h=0.0003&v=0.0000&f=90.0000&fpopen=true
<krpano>
<events name="fpshowEvent" keep="true" onTourStart="if(fpopen,showFloorplan(); );" />
</krpano>
That code can be added to your project via the"Include of a XML file"-additional plugin, to have it permanent over rebuilds.
Annis likes this post.
Sean King
Liked in: 4 posts
by Sean King » Thu Aug 25, 2016 6:25 am
Regards,
