I'm struggling with a request of a client that wants to have a customized design for his tour. In attached pieces you can see the kind of design he wants. So I basically started a new control bar, duplicating "d-pad control bar". I edited alpha in the template file to have a solid color. I then edited graphics to have a plain round instead of the cross and edited so far the color of "share" button as if arrow are white, I end up with a "share" button white as well. So now it's plain red and doesn't change on hover and click (I still need to edit the "full screen" button but as I have found the code lines, it will come later). I have indeed 3 things I'm struggling with : -I'd like this controls to be right centered in the project but obviously there's no option like that in the basic design -I'd like to have the share button not in the "horizontal" bar but instead in the vertical one (under "full screen" button if possible) -I'd like to increase the size of both "share" and "full screen" as well as reduce size of circle with arrows.
To be honnest, I can tweak with some basic code lines but for the 3 mentioned problems, first I have no clue if it's possible and then where should I look for to do it.
For the size of buttons, graphics are 30x30 so I thought that by increasing size, it would follow. But it didn't. I tried a graphic at 40x120 and then edited this code line in plugin.xml : <feature id="fullscreen" name="tr:Fullscreen" enabled="true" guiIcon="btn_enter_fs.png" crop="0|0|40|40"> No effect.
If anyone could help me and point me what to look for it would be much, much appreciated ! Thanks for sharing your knowledge ! Best of all Francis
