Help with custom KRPANO code
bitbyter
Liked in: 3 posts
by bitbyter » Tue Jul 26, 2016 9:24 am
Hi all - I've been attempting to learn how to add text using the krpano showtext plugin as demonstrated here:
http://krpano.com/examples/118/examples ... tyles.html
and documented here:
http://krpano.com/plugins/showtext/#top
My ultimate goal is to have the name of the current panorama displayed automatically with custom styling.
I've used the "Include of a XML file" plugin to include the showtext.xml file however I can't even seem to manage a "Hello World" message. Can anyone point me in the right direction to get a simple message displayed ?
Thanks, Scott
Re: Help with custom KRPANO code
by Annis » Tue Jul 26, 2016 10:13 am
You should ask this on the KrPano forum, as you'll find more users there than here.
Kolor does not provide any KrPano support.
bitbyter
Liked in: 3 posts
by bitbyter » Tue Jul 26, 2016 3:59 pm
sorry, should have explained further that I'm trying to do so by creating a Panotour Pro plugin that I can re-use in my projects without having to edit produced code - that's why I'm posting here.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Fri Jul 29, 2016 9:32 pm
So i assume you have copied the "showtext.xml"-contents to your plugins "template.tmpl"-file, right?
Then, for example, modify the "Default Textstyle" as follows (only the first line modified):
   <hotspot name="h1_t" onhover="getmessage(panoname,get(scene[get(xml.scene)].titleid));showtext(get(panoname));" keep="true" >
      <point ath="-72.9589" atv="-30.4572" />
      <point ath="-70.4091" atv="-27.2998" />
      <point ath="-67.2064" atv="-31.3229" />
      <point ath="-59.0580" atv="-16.6194" />
      <point ath="-55.6416" atv="-18.9404" />
      <point ath="-64.4720" atv="-33.8924" />
      <point ath="-59.5064" atv="-37.4353" />
      <point ath="-63.7152" atv="-42.0385" />
   </hotspot>
Hovering over the "T" should now give you the pano names.
EDIT: changed the modification to actually give the panos' names, not just their ids.
