JS function to toggle Panotour Map
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Wed Apr 27, 2016 4:31 pm
Hi Guys,
I have been searching the forum/docs and been pulling out my hair with this one all day, so thought is was about time to ask for help!
I wanted to add either a CSS class or ID to a Simple Button (plugin) in order to be able to style it responsively. From what I have read on similar threads, although it sounds simple, its actually a massively long winded process and pain to do.
Therefore, I decided I would just create my own HTML template (clone of Bubbles) with a button to toggle a Pantour Map sidebar:
<a href="#" class="toggleMapButton" title="Toggle Google Map"></a>
Obviously I need to link this button to a JS function for toggling the map sidebar, I couldn't find the existing script to do this so I started inspecting the code and seeing what the existing JS was doing. It looked like mainly it was just CSS changes, so I ended up with a script like this and added it to the bottom of the functions in the index.html page of my custom template:
/* Toggle Map Custom Function */
$('.toggleMapButton').click(function() {
   $("#mapcontainer").addClass('ui-resizable');
   $("#mapcontainer").css({"width":"30%","display":"block","position":"absolute","z-index":"4003","height":"100%","float":"left"});
   $("#panoDIV").css({"width":"70%"});
   $("#mapcontainer .ui-resizable-handle").css({"z-index":"90","display":"block"});
   $(".gm-style-pbc").css({"display":"block"});
However, this is a complete bodge job and and although the sidebar opens etc, the Google Map doesn't load.
So my question is: Surely the JS function to toggle the map already exists somewhere? So how can I trigger it using my new custom button in the HTML? I know the templates have examples of functions for various things, but none of them use the map plugin, so I have nothing to compare it to.
Any help of advice would be appreciated! Even if its just pointing me to where the existing functions are.
Many thanks in advance,
Mike
Pantotour Pro 2.5
Likes: 14 posts
Re: JS function to toggle Panotour Map
by bdd » Mon May 02, 2016 2:18 pm
Add the following code in your HTML file, if it does not exist yet :
         var panotourPlayer = null;
         function getTourPlayer() {
            if ( panotourPlayer == null ) {
               panotourPlayer = document.getElementById('krpanoSWFObject');
            }return panotourPlayer;
Then to open or close the map will be done with those calls :
         getTourPlayer().call('panotourmapsOpentourmap()');
         getTourPlayer().call('panotourmapsClosetourmap()');
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Tue May 03, 2016 3:19 pm
Thanks Bdd, that worked great!
Two more questions, if that is ok :)
1) Is there a toggle version of that function? Ideally I want to toggle the map open/closed using a single button.
2) What would be the function to toggle hide/show of hotspots?
Many thanks, Mike
