Vr mode doesn't work with Bootstrap-plugin?   [SOLVED] - View the solution
hermandesmet1980
by hermandesmet1980 » Tue Mar 15, 2016 2:06 pm
Hey all,
I just added a toolbar to my big 360° project with the VR-button enabled (only in mobile mode).
http://www.brusselsfromabove.be/
Problem is: when I browse to the tour with my iPhone, it doesn't work!
Any idea how this comes? When I enable it on desktop mode, it doesn't work either, also not on the local server.
The website is made with the custom bootstrap external commands plugin. Do I need the upgrade this plugin in order to get the vr-mode to work? Also the fullscreen mode isn't exactly fullscreen...
I hope someone can help a little bit...
Kind regards,
Herman
Re: Vr mode doesn't work with Bootstrap-plugin?
by Annis » Tue Mar 15, 2016 4:01 pm
Which template specifically are you using?
Which version? (you can find the date at the end of the bootstrap template's template name)
Or are you using only the plugin? The question of the version still stands, see which version of the templates you have installed so we know which version of the plugin.
hermandesmet1980
by hermandesmet1980 » Tue Mar 15, 2016 4:13 pm
The version is: "Bootstrap_External_Commands_Full_Page_w_Colors_2015_04"
Kind regards,
Herman
Re: Vr mode doesn't work with Bootstrap-plugin?  [SOLVED]
by Annis » Tue Mar 15, 2016 4:16 pm
Okay then there have been several versions since then, download the latest versions of the bootstrap templates, I haven't had any issue using the VR Mode button in the latest version.
hermandesmet1980
by hermandesmet1980 » Wed Mar 16, 2016 12:26 pm
Okay, thanks very much! I replaced the plugin files, and reworked some CSS-bugs and now I got it working!
Thanks!
