Developing a plugin
udrh
Developing a plugin
by udrh » Fri May 29, 2015 1:56 am
Hi everyone,
I am trying to develop a basic google analytics plugin. However, I am having some difficulty getting started.
My initial goal is to set up an event listener that can respond with an action whenever a hotspot is clicked. Ideally some information about the hotspot can then be extracted and sent to google analytics.
As a starting point I’m thinking I could get a simple javascript plugin set up, with an analytics.xml file included by the PTP ‘include xml plugin’. Example ‘analytics.xml’ code:
<plugin alturl="my_analytics.js" name="my_analytics" keep="true">
</plugin>
<events name="my_load_events" onxmlcomplete="plugin[my_analytics].testfunction1();" keep="true"/>
I’ve had a bit of a go with using the krpano javascript template as the ‘my_analytics.js’, but I can’t get access any functions, as I keep getting ‘unknown action’.
Any ideas where I’m going wrong?
Thanks,
Michael
Re: Developing a plugin
by benji33 » Mon Jun 01, 2015 9:45 am
Difficult to respond without a little bit more informations.
Your my_analytics.js file is a krpano plugin ?
udrh
by udrh » Fri Jun 19, 2015 5:07 am
Hi, thanks for your reply.
Yes, I'm trying to use the krpano javascript plugin template (http://krpano.com/docu/plugininterface/#js) as the 'my_analytics.js' file.
I have created a basic PTP test tour. As part of this I am using the 'include xml' PTP plugin to include an xml file ('analytics.xml') which has the few lines of code to set up a javascript plugin (see my first post). At the moment, the 'my_analytics.js' contents are identical to the 'plugintemplate.js' from the krpano site, but I'd like to have something that works so I have something to build on.
I'm running into trouble when I try to call any functions from the plugin, where I get an error saying:
WARNING: unknown action: plugin[my_analytics].testfunction1
I don't know if something with the javascript template needs to be changed for PTP, or if my xml syntax for creating the plugin or calling functions is wrong, or something else entirely.
Thanks again,
Michael
by benji33 » Thu Jul 23, 2015 9:53 am
Is it possible to have a zip of the generated tour to help you with the code ?
udrh
by udrh » Thu Oct 15, 2015 5:57 am
Hi again,
Sorry for the lengthy delay in posting a followup. In coming back to this after a long absence, I'm trying a different approach which looks like it could be an easy way to get at least some basic view stats.
In the html page I've got the standard Google Analytics embed script in the <head> part of the html page.
In PTP I am using the 'Call actions on tour events' free plugin, and for the 'React when the panorama starts, after introduction effects' option I have the following 'Call a javascript action' js code:
ga("send","event","panorama","load",%p);
This sends event data to my analytics account all fine (hooray!). However, the %p keyword isn't resolving as the panorama name ('%p' is all that goes to analytics). Do you know what I could use instead of %p to show the current panorama name?
Cheers,
Michael
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Oct 15, 2015 7:04 am
I won't be able to help you with the code but I just want to point out that PTP 2.5 beta has an analytics plugin, have you checked it out?
udrh
by udrh » Thu Oct 15, 2015 10:05 am
No I wasn't aware - I'll have a look tomorrow.
Vishal Mathur
Likes: 8 posts
by Vishal Mathur » Mon Jan 11, 2016 8:14 am
Cliquetsy wrote:I won't be able to help you with the code but I just want to point out that PTP 2.5 beta has an analytics plugin, have you checked it out?
Hi, I'm running PTP2.3.2, I can't view the Analytics plugin in the style library, any idea where to find it?
Also while I try to check for updates for PTP 2.3.2 to upgrade to PTP 2.5 beta, the message says you are already running on the most updated version.How to upgrade to to PTP2.5 beta to use Analytics pluggin?
by Annis » Mon Jan 11, 2016 9:22 am
The Analytics plugin is in v2.5, so you will not find it in your 2.3 version..
Since it is not a stable release, it doesn't yet count as an update until the final version, then you will be able to find it by searching for updates.
You can download v2.5 from the bottom of the Panotour downloads page (http://www.kolor.com/panotour/download/#beta).
