Learn LIVEPANO
ken1127
Learn LIVEPANO
by ken1127 » Sun Sep 02, 2018 5:41 am
Hello, I am learning LIVEPANO step by step from the film.
At present, it is impossible to complete a perfect work, there is a problem of stitching color between photos and videos, and there is also a problem that the sound of the film and the video are not synchronized.
Will the livepano software operation, whether there is a written form of instructions, for example: pdf type
ken1127
Re: Learn LIVEPANO
by ken1127 » Sun Sep 02, 2018 11:28 am
When the vlc software captures the movie into a picture
When operating the APG software
I press "i"
Change the captured image to the fisheye lens
Q1:How muchm mm do I need to change the focal length of the lens?
(I see that your company’s introduction film is changed to 50mm)
Q2:Do you want to save the captured image when you save the .pano file?
Q3:Do you want to hide the captured image when rendering it as a picture?
