LivePano video finishes jumps to another pano   [SOLVED] - View the solution
Miki
by Miki » Wed Aug 08, 2018 3:24 pm
Hallo, using PT with LivePano (2.5.13) and have this need - tour has the pano A where Livepano video is put and auto-plays. After this video finishes, need immediatelly to jump to pano B, using littleplanet transition and ideally have pano B rotated/zoomed to same position as A was. Can anybody help me how to manage it? Thanks in advance.
Re: LivePano video finishes jumps to another pano
by benji33 » Fri Aug 17, 2018 12:12 pm
There is no way to do it with the software. You have to edit the generated xml files to add an action when the specific video spot is ended.
Miki
by Miki » Fri Aug 17, 2018 2:12 pm
OK, I accept it. Can you help me with? Link to some sample, doc etc? Thanks in advance.
by benji33 » Tue Aug 21, 2018 1:55 pm
Send me an online url (in private if needed) and I will help you to edit the right part of it.
Miki
Re: LivePano video finishes jumps to another pano  [SOLVED]
by Miki » Mon Sep 03, 2018 4:15 pm
I have it probably... need to add event and complementar action. For anyone who will need it in future..
