Livepano not aligned with Panorama
andue
by andue » Thu May 24, 2018 8:02 am
I can't get Livepano to work here. Stitching works perfectly and the video frame aligns perfectly with the panorama. But when the tour is generated, the livepano video file is not aligned with the panorama. I need to manually resize and position the video file to get them to align more or less well. See screenshots attached.
Any help with this is appreciated!
Likes: 14 posts
Re: Livepano not aligned with Panorama
by bdd » Thu May 24, 2018 2:41 pm
Can you share with us the resources of your livepano :
the still images
the frame used to "stitch" the video and the stills
the stitched equirectangular
and the .pano file
(If the frame was correctly extracted, we do not really need the video file )
Having those resources will help us understand why the final video is not aligned with the scene image .
andue
by andue » Thu May 24, 2018 3:03 pm
Here are the files to download. I converted the tiffs into jpegs to keep the files smaller: https://we.tl/NVjw74fxLb
Likes: 14 posts
by bdd » Fri May 25, 2018 2:17 pm
Les fichiers envoyés ne correspondent pas aux captures d'écran ci-dessus .
De plus, il manque un fichier pour pouvoir ouvrir votre fichier Brunnen.pano : le fichier rechts.tif
Et pouvez vous me dire si c'est rechts.tif ou links.tif qui est la frame extraite de la video ?
Likes: 14 posts
by bdd » Fri May 25, 2018 3:00 pm
En regardant le cas que vous m'avez envoyé, et en supposant que la frame de la video est "links.tif", il semble que la frame n'est pas correctement assemblée dans le *.pano
Ce qui entraine donc un mauvais placement du livepano .
andue
by andue » Fri May 25, 2018 3:28 pm
Hi Gérald,
sorry but my French isn't very good. In school I chose latin instead ;)
Sorry about the missing frame. You can download it here: https://we.tl/zXfgI9faX6
Andreas
Likes: 14 posts
by bdd » Mon May 28, 2018 10:09 am
Hi Andreas,
Thanks for the missing frame.
And sorry for my french answer. I don't know why I switched to french in this thread.
Here is what I told you :
In your Autopano project, the extracted frame is not aligned with the scene background, that's why the livepano will not be aligned, because it's the position of the frame in the stitched project that will be used to place the video.
