Live Pano import from krpano
Ramona86
by Ramona86 » Tue Mar 20, 2018 10:44 am
i have the same problem like all other. The mask problem. On mobile devices it looks fine, on PC IE oder Chrome you see the video not realy like the example pictures from the kolor webiste.
Kolor works on top from krpano. But the krpano livepano looks realy great. Easy to manage and 3d sound. But the rest is not so good like panotour.
My question, is it possible to make the livepano panorama with krpano and import it in the kolor panotour pro tour?
Thanks for your help.
Moni
Likes: 14 posts
Re: Live Pano import from krpano
by bdd » Tue Mar 20, 2018 11:53 am
Ramona86 wrote:My question, is it possible to make the livepano panorama with krpano and import it in the kolor panotour pro tour?
Yes you can do it, but not as simply as an "import".
You'll have :
. either to create a video spot using the "krpano livepano", and then the tricky part is to find the correct 4 corners of the video spot,
. or to edit the kpt file, with a text editor, to add the video spot using the translated coordinates of the "krpano livepano". The tricky part of this second solution is to find the formula that converts the coordinates .
