Email Mistake Purchasing Livepano Addon   [SOLVED] - View the solution
kush2904
by kush2904 » Mon Mar 05, 2018 6:23 am
I had purchased Panotour Pro several months back with my email_id_1.
2-3 days back I bought LivePano Addon Plugin by mistake with email_id_2.
Livepano registration doesnt work. I need help from Kolor Team to sort this out. I need LivePano email/username change, so i can successfully register. I have a project deadline, need this sorted ASAP.
Who to contact for this scenario ?
Rami
Re: Email Mistake Purchasing Livepano Addon
by Rami » Mon Mar 05, 2018 11:43 am
Hi and thanks for your purchase. We saw you also sent us an e-mail.
No problem, we'll sort this out ASAP and will keep you informed by e-mail.
Have a good day!
Rami
kush2904
by kush2904 » Mon Mar 05, 2018 11:46 am
Thanks a lot for the words. Was quite worried. Let me know if you need the email id or invoices.
