Livepano not working in VR
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Wed Feb 28, 2018 1:52 pm
Live pano's stopped working in VR,
i have tried :
Autoplay
Paused on start
Paused on start + buttons
they start working when i tap the screen but that is not a usable situation using VR
Panotour pro: 2.5.9
tested on:
Iphone latest OS
Android
Siewers
Likes: 4 posts
Liked in: 14 posts
Re: Livepano not working in VR
by Siewers » Wed Feb 28, 2018 4:21 pm
I found out that if you remove the audio channel from the video it works.
for the project i'm doing now the audio is essential so that is not an option.
Auto playing a audio file is also blocked.
benji33 could you help?
by benji33 » Thu Mar 01, 2018 9:50 am
Panotour Pro 2.5.10 will have a better approach for audio on mobile devices.
The case with Livepano and video spot is more complex. Why ? Because the autoplay policy of browsers avoid the play of videos with sound.
You need a touch action to activate it which is "not possible" with a headset because click are binded on hover events which is not a user gesture event.
The only way to activate a video with sound is to instanciate it and pause it until the play when opening the VR tour with the first touch. But Panotour livepano and video spots are only created when displayed and used.
An issue is opened on our side but needs a big refactor of the video elements.
Siewers
Likes: 4 posts
Liked in: 14 posts
by Siewers » Thu Mar 01, 2018 1:42 pm
Is there a way to start a audio stream at the same moment as we start the video?
The livepano would start paused and on clicking the play button the audio and the video would start playing together?
Users don't need to pause the video, it is for a training so we can instruct them to let the video continue playing
by benji33 » Fri Mar 02, 2018 12:44 pm
The only way is to implement a permanent hotspot hidden on not needed scenes and played/paused on start.
Panotour is not able to manage that at this time and you have to do it manually with krpano code.
https://krpano.com/docu/
https://krpano.com/plugins/videoplayer/#top
