Livepano in non equirectangular panorama?   [SOLVED] - View the solution
yaro
by yaro » Tue Jan 30, 2018 8:10 pm
Is it possible to insert an live pano in a non equirectangular panorama? I don't want to show the floor and the sealing.
I have done some 360X45 degrees panoramas and the software tells me ( You need an equirectangular panorama loaded before importing livepano )
Is there a way around this ??
Best regards.
