LIVEPANO   [SOLVED] - View the solution
virtualtur-md
LIVEPANO
by virtualtur-md » Wed Nov 15, 2017 10:54 am
Good afternoon :)
I want to show you two links and ask for such a thing, you can teach me all the chips that are in these two tours (the first tour is found on your website, in your works)
How much will it cost?
Is it possible to implement this in the graphical shell panotour
http://www.kolor.com/2017/06/27/case-st ... y-we-shop/
http://pue.zus.pl/WIPanorama/
From here we need a sorting and video assistant
as well as all these arrivals to the arrows, all these movements
Here and so in the corner at each stand you can call an assistant
1) that's how to allocate areas
2) here and so to choose separately each product in its category
3) each product has its own window with a description
4) after each description there is a link to the site - to the page with this product
Re: LIVEPANO
by Annis » Wed Nov 15, 2017 3:27 pm
For a tour where you have the actual tour on the one side, then text or videos and such outside the tour, maybe have a look into using a custom HTML template. Have a look (or use as a base if you have the skills) the ones here: http://www.kolor.com/wiki-en/action/vie ... _Templates
For 1 and 2, you'd need to use polygon hotspots to draw around the interactive area.
http://www.kolor.com/wiki-en/action/vie ... dd_Polygon
For 3 and 4, a website box that opens either a local html page or a website (it's an iFrame essentially). For the tour you're screenshotting though, I believe they used their own lightbox instead of using the website box plugin from Panotour. There was a lot of hand coding outside of the tour.
http://www.kolor.com/wiki-en/action/vie ... ebsite_Box
http://www.kolor.com/wiki-en/action/vie ... _HTML_file
virtualtur-md likes this post.
virtualtur-md
Re: LIVEPANO
by virtualtur-md » Wed Nov 15, 2017 3:40 pm
it is through codes and APIs, explanations of what functions and what they do, how to use them correctly, so that everything functions and interacts with each other, so as to understand the principles of work. Present this knowledge as a lecture, an educational course, a master class, live lessons, or through video screen recordings (in the most convenient and understandable way :)
The goal is to learn, to learnin the future, to use everything necessary to create such interactive tours.
How to create masked areas like in a hardware store, how to create functions by clicking on arrows and / or links that will open a wide range of videos and / or short descriptions.
1) Can you do this?
2) Teach me?
3) How much will it cost?
virtualtur-md
Re: LIVEPANO
by virtualtur-md » Thu Nov 16, 2017 1:30 pm
help me please :)
Re: LIVEPANO  [SOLVED]
by Annis » Thu Nov 16, 2017 5:02 pm
virtualtur-md wrote:1) Can you do this?
2) Teach me?
We do offer training for use of the software (information here: http://www.kolor.com/academy/) but it does not deal with teaching your krpano coding or web development. We don't offer either of those in tech support either unfortunately, so no courses, screen recordings or master classes.
As for the price of training, I don't know you will have to use the contact form on that page for information about Academy.
virtualtur-md
Re: LIVEPANO
by virtualtur-md » Fri Nov 17, 2017 11:09 am
everything is clear in general, thanks a lot :)
