Livepano not blend correctly   [SOLVED] - View the solution
vicliciouss
by vicliciouss » Tue Nov 07, 2017 4:59 am
I'm recording video livepano the same camera with shooting 360 photo, same lens, same angle, same height. But the livepano not blending correctly. It seems just put the video to the 360 photo, not stitch correct the point on it. Please view screenshot.
And when i draw polygon on step 4, it does not display people on video for me to see. I'm make sure the video begin play with people standing.
Please help,
Thank you
