Mask does not appear to be working
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Mon Oct 02, 2017 11:28 am
Hi All
I am just trying my hand at a LivePano. The mask does not appear to be working correctly. Any help appreciated. All software up to date. http://tourmaps.com.au/test/
Steve
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: Mask does not appear to be working
by signmaster » Mon Oct 02, 2017 1:48 pm
Just checked works OK on mobile?
by benji33 » Wed Oct 18, 2017 11:13 pm
Tested on my macBookPro with Intel GPU and Chrome browser without any real issue of too much visible mask.
Is it possible to send us your computers and devices specifications (Windows/macOS - GPU - Chrome/Firefox/Opera/Safari/Edge/IE) to test it please?
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Wed Oct 18, 2017 11:49 pm
Hi Benjamin
Just checked it on Chrome and Firefox here at work, (previous image from home PC) and it works quite well. Also just checked on Internet Explorer and Opera Neon, very poor, see below. My PC at work is running Windows 7, i7 950 CPU 12Gb ram.
Steve
by benji33 » Fri Oct 20, 2017 11:27 pm
Thanks for these tests.
Here is a forum topic linked to this mask issue : be careful with this link, it's a complex topic for a complex environment and a complex solution with many tensions
viewtopic.php?f=115&t=36543
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sun Oct 22, 2017 10:47 am
Hi Benjamin
That thread is very confusing.
Just checked on my home PC and it is very bad as per the first image I posted, both are similar computers except my home PC runs Windows 10 and my work PC has Windows 7. My work PC using Chrome and Firefox it works quite well but on my home PC using Chrome and Firefox it is very poor. Perhaps related to the operating system?
Steve
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Mon Oct 23, 2017 1:16 pm
Hi Benjamin
Don't know if this will help but I did some tests on some PCs at work and my 2 PC's at home with different browsers.
Windows Version Browser Version Comments
Testing live pano work PCs
Windows XP SP3 IE 8 OK
Windows 10 Chrome Mask visible, bad
Windows 10 Edge OK
Windows 7 IE 11 Mask visible, bad
Windows 7 Chrome OK
Windows 7 FireFox OK
Windows 7 Opera Neon Mask visible, bad
Windows 7 Opera 42 Mask visible, bad
Testing Home PC i7 desktop
Windows 10 Edge Mask visible, not as bad as the other browsers
Windows 10 FireFox Mask visible, bad
Windows 10 Opera 48 Mask visible, bad
Windows 10 Brave Mask visible, bad
Surface Pro 3 i7
Windows 10 Edge OK
When I say "OK" the result is quite acceptable.
Steve
charles360
by charles360 » Sat Dec 23, 2017 9:15 am
Tested on Mac 2011
Livepano not working in Safari 11.0.2
feyona likes this post.
