Hotspot to play and stop a livepano
vista360chile
Liked in: 5 posts
by vista360chile » Wed Aug 30, 2017 4:32 pm
Hi guys!
i need to place a HOTSPOT and give it the action to play ad stop a livepano.
is it possible?
Re: Hotspot to play and stop a livepano
by benji33 » Thu Aug 31, 2017 10:21 am
It's not possible through PTP interface.
But you can do it manually into the code.
As a livepano is like a video spot, you have to call the "play" and "pause" action of the livepano through your toggle button.
Omni VR
Likes: 4 posts
Liked in: 4 posts
by Omni VR » Mon Sep 11, 2017 8:12 am
benji33 wrote:It's not possible through PTP interface.
Hi @benji33, could you be more specific, we also want to know, because we are using livepano as well.
We give VR a smile!
by benji33 » Mon Sep 11, 2017 9:41 am
A livepano has the "onclickspotvideoXY" (where XY is the number of the video spot into the xml) action into the YOURTOUR.xml file. This is the toggle play/pause action of the spot.
Simply add a point spot with a basic action as "go to panorama".
Then you have to edit the hotspot code to make it as a toggle button.
Have a look on "onclickspotpointYZ" action where YZ is the number of the point spot and replace the code into by :
<action name="onclickspotpointXY">
    onclickspotvideoYZ(true);
</action>
You also have the ability to use through the interface a play / pause button over the livepano.
You can also use this functionnality and change the asset manually into the code to use you own icons.
Have a look on the play and pause buttons into YOURTOUR_skin.xml file nammed: spotvideoXY_playbtn and spotvideoXY_pausebtn
Omni VR likes this post.
Omni VR
Likes: 4 posts
Liked in: 4 posts
by Omni VR » Mon Sep 11, 2017 10:04 am
benji33 wrote:A livepano has the "onclickspotvideoXY" (where XY is the number of the video spot into the xml) action into the YOURTOUR.xml file. This is the toggle play/pause action of the spot.
</action>
Thanks! We going to give it a try!
We give VR a smile!
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Wed Sep 27, 2017 11:45 pm
Is it possible to have the video aspect play automatically when that part of the pano is in view?
A bit like the panoramic sound plugin. I think it would make for a simpler and more streamlined experience for the user. In some cases...
by Annis » Thu Sep 28, 2017 2:38 pm
Well in the flash player, videos could also have directional sound but they didn't play/pause with the direction.
