Problems with Sony Alpha 77
Moni86
by Moni86 » Fri Nov 27, 2015 7:09 pm
Hello there,
I use to create virtual tours, the Sony Alpha 77. Now I have a video recorded with this camera to enjoy it as a Livepano.
The tripod, the aperture & exposure is the same as in the Pano Creation.
Unfortunately, the video takes on a different image section in the same place. Is there a trick? Or I have to buy a new camera?
Many thanks for your help
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Problems with Sony Alpha 77
by Cliquetsy » Sat Nov 28, 2015 11:06 am
What do you mean it takes on a different image section in the same place? It isn't stitched correctly?
Moni86
by Moni86 » Fri Dec 04, 2015 8:37 am
It means that the Video recording has a Little zoom, and yes thasts the reason why the stiching is not correctly i think.
MetroRuss
by MetroRuss » Thu Jul 14, 2016 8:13 am
Hi there,
I have had ptp with paid livepano and apg for 3+ years now and have never been able to solve this same problem that the OP has posted. I was shooting with a Sony A57 up until a few months ago when I got a A77ii.
I just tried to publish a live pano a fee moments ago following the tutorials very precisely but ended up in a huge fail.
Admins, is there a know issue with the Sony A57 A77 type cameras?
Because last time I tried it with the A57 I came to the same possible issue that the movie depth of field may be off when compared to the photograph dof, therefore creating unstitchable livepanos.
Can we please get some official comments on this issue.
Thanks.
by Annis » Mon Jul 25, 2016 9:46 am
Can you share source files (photos + video + frame + your panorama) for a Livepano shot with that camera?
What is your exact shooting config? (Video parameters, what lens..)
There aren't any particular issues related to those cameras that I know of.
MetroRuss
by MetroRuss » Tue Nov 22, 2016 9:25 pm
Hi Annis, sorry I missed this post.
What is the best way to share these files?
Regards,
Russ
by Annis » Wed Nov 23, 2016 9:34 am
Upload to Dropbox or another file sharing site and send me the link via PM.
nicgac
Likes: 3 posts
by nicgac » Sat Dec 10, 2016 12:45 am
Hi all,
In case you are shooting in mp4, Sony has a tendency to cheat a little bit the system. Actually, the pixel ratio is reduced (the pixel becomes rectangular) - though when played with the right video codec, it is then extended back to it's square shape.
For example, a video shot in 1080i is actually a 1920x1080 resolution file, but 1440x1080. I won't go too much into details, and I'm not sure that the latest Sony cameras have that gitch, but the Nex series had that serious hiccup up to the lastest models.
Use a video tool such as Final Cut to put the file to its final size and the correct pixel ratio, and then do your screenshot.
Not sure this helps, but good luck.
N
Annis likes this post.
MetroRuss
by MetroRuss » Wed Dec 27, 2017 7:54 am
Hello, I have not been shooting panos lately but I do think I have figured out why the livepano does not play nice with sony a77. If you have steady shot turned on for video, the field of view will crop in order to calm down any shaking. Turn it off and you will see that it will not crop any more.
I have not tried it and probably never will but I hope it can help some one else. Please post back if you can confirm this is the case.
