Mask not working
shovay
Likes: 3 posts
Liked in: 3 posts
Mask not working
by shovay » Tue Nov 03, 2015 11:34 am
I'm not a novice in the work with the plugin
in version 2.3 everything was fine .I am currently using version 2.5 beta 4
I did the whole process starting with stiching,
video segment appears only as needed at the beginning, and then mask disappears. Also, the video quality is highly variable, it is possible to do something with this?
https://dl.dropboxusercontent.com/u/688 ... /test.html
Re: Mask not working
by Annis » Tue Nov 03, 2015 11:46 am
What do you mean by the mask disappears?
There is no way of controlling the encoding of the video.
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Tue Nov 03, 2015 11:48 am
Look at the tour of the link I sent,   you can see a rectangle around my video fragment. despite the fact that I have created a mask
by benji33 » Wed Nov 04, 2015 11:11 am
Hi this rectangle is due to the video codecs which apply color corrections. In fact the mask is working but the panorama parts are displayed with the video codec not the image engine of the browser.
We are looking on a way to be able to avoid this kind of problem.
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Wed Nov 04, 2015 3:02 pm
Hi Benjamin
I use video obtained directly from Mark2, tell me what codec to convert one of those that you check and I will try to do it
by benji33 » Thu Nov 05, 2015 9:23 am
I talk about the video codec used by the browsers.
Chrome has own codecs, Firefox use Windows codecs as IE for instance, etc ... So each browser has a different optimisation.
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Thu Nov 05, 2015 11:31 am
Tested in Chrome (have a problem with the codec) Firefox (there is a problem with the codec)
Explorer (everything looks great)
Chrome to Phone :Samsung S6 +Nexus 5(old) (looks great)
You want to find a solution?
dimitrilee
by dimitrilee » Sat Dec 19, 2015 4:46 pm
I have the same issue , 2.5 RC2
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Mon Jan 18, 2016 9:17 pm
Me too, the same issue 2.5.0 64 bits, mac OS 10.11.2., and canon 5D2, sony A7R
juststar likes this post.
juststar
by juststar » Thu Jan 28, 2016 10:58 pm
