how many live videos
leen
by leen » Tue Apr 28, 2015 4:05 am
how many videos we can add in a virtual tour, if I have a virtual tour of 10 panoramas and can I use livepano on all these panoramas.
Which software is best for rotating the video taken from canon5d mark 3?
Re: how many live videos
by Destiny » Tue Apr 28, 2015 4:20 am
Hi...
I have seen panos with 4 Live Panos a full Tour could have many.. I guess if you try to add too many it will all grind to a stop... As for rotating your video, you do not need to do that... PTP will locate to the correct orientation using the reference image...
by Annis » Tue Apr 28, 2015 8:52 am
Don't change the orientation of your video, that can cause problems later. If it needs to be rotated, Panotour will know to do that from the stitching of your .pano.
This is a good example of a tour with several of Livepano: http://suwalkiplaza.com.pl/wycieczka/suwalki_plaza.html
Most lifts and escalators in that tour are a Livepano.
