Read this before posting - À lire avant de poster
by Annis » Mon Jul 28, 2014 3:09 pm
EN:
This sub-forum is for users using Livepano, who need help using it or who have a bug to report, crashes, stability issues, etc.
Before posting, have a look at these useful links, in case that solves your problem:
- Livepano Frequently Asked Questions
- Importing a Livepano documentation
- Stitching a Livepano in Autopano
- ChaDian Tea-shop tutorial (1rst and 3rd video are about Livepano)
You may also want to do a search for a bug, before reporting it.
When posting, make sure that you provide as much information as possible:
- Your computer specs
- Which version of Panotour Pro and Autopano you are using
- When does the crash (if there is one) occur exactly?
- Can you recreate the problem? (If you can, what is your workflow)
- Is the same using a different project? If not, what's the difference between the two?
- Screenshots, we love those
- Can you share the project source files (using Dropbox for example) ?
- etc..
The more details we have to work with, the easier it will be to find a solution.
Once the issue is solved, check the solved button on the top right corner of the post that provided you with the solution.
Make sure you post one topic per issue, so that they can be dealt with separately.
Thanks,
________________________________________________________________________
FR:
Ce sous forum est là pour les utilisateurs utilisant Livepano, qui ont besoin d'aide à l'utiliser ou ont des rapports de bugs, problèmes de stabilité du logiciel, rapports de crash, etc.. à nous faire partager.
Avant de poster, jetez un coup d’œil à la (avec des liens utiles), car vous pourrez peut-être y trouver une solution à votre problème.
- Foire Aux Questions Livepano
- Importer un Livepano documentation
- Assembler un Livepano dans Autopano (didacticiel en anglais)
- Didacticiel de la boutique de thé ChaDian (1ère et 3ème vidéo sont sur Livepano)
Merci de faire une recherche dans avant de poster votre message, pour vérifier que le bug n'est pas un cas connu et traité.
Quand vous postez, veillez à nous fournir le plus d'informations possible:
- La configuration de votre ordinateur
- La version de Panotour Pro et Autopano
- Des captures d'écran
- Quand s'est produit le problème ?
- Pouvez-vous recréer le problème en faisant la même manipulation ? (Si oui, dîtes-nous quelle est la manipulation à faire)
- Cela se produit-il avec d'autres projets ?
- Pouvez vous partager les fichiers source (par Dropbox par exemple) ?
- etc..
Une fois la solution trouvée, cliquez sur l'icône "check" en haut à droite du post qui propose la solution pour noter le topic comme étant résolu.
Ne créez qu'un seul topic par question, pour que chaque solution puisse avoir sa solution.
Merci d'avoir lu.
